CA themostat housing |
DCAC
Joined: 20 Oct 2018 Location: east central SD Points: 522 |
Topic: CA themostat housingPosted: 15 hours 48 minutes ago at 7:40pm |
Looking for the aluminum thermostat housing for a late CA. It's different from the cast one, perhaps the aluminum one is aftermarket? Thanks in advance!
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5260 |
Posted: 4 hours 37 minutes ago at 6:51am |
The aluminum thermostat housing was used on the very late production CA tractor. These were highly susceptible to corrosion and often bolts broke off when taking them apart. You can replace it with a cast iron one, it just won't be the bypass type.
DCAC
Posted: 3 hours 11 minutes ago at 8:17am |
Thanks Paul! That's probably what will have to happen, unless a good one can be found, will at least get it going after a little surgery was performed,
CentralMNCA
Posted: 41 minutes ago at 10:47am |
There is one of the aluminum T stat housing on EBAY , in the ebay search
this is the site # 146629216296
