CA themostat housing
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Topic: CA themostat housing
    Posted: 12 hours 30 minutes ago at 7:40pm
Looking for the aluminum thermostat housing for a late CA.  It's different from the cast one, perhaps the aluminum one is aftermarket?  Thanks in advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 19 minutes ago at 6:51am
The aluminum thermostat housing was used on the very late production CA tractor. These were highly susceptible to corrosion and often bolts broke off when taking them apart. You can replace it with a cast iron one, it just won't be the bypass type.
