CA steering lube
kenbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Topic: CA steering lube
    Posted: 06 Oct 2017 at 12:16pm
My owners manual proudly proclaims there are no grease zirks on the tractor.  My new CA has one. Looks like a previous owner rigged up the steering fluid fill hole with a zirk.  I think the tractor has pretty tight steering, maybe 15-20% slop.  Should I leave well enough alone, or will grease damage the gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2017 at 12:22pm
when the shaft seals start to leak out the gear lube, it was common to put a zerk in the fill hole and fill with grease instead. Adding several pumps of new grease would be fine.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2017 at 1:54pm
You'd be better off taking that grease zerk out its supposed to be a plug. if it leaks oil out put pourable grease instead, gun grease wont lube the pedestal bearings. pourable grease (also know as corn head grease) will at least get down to the bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2017 at 2:19pm
Thanks...good info!
