CA Starter Locking Stud
1955CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Topic: CA Starter Locking Stud
    Posted: 16 Jun 2024 at 5:03pm
Anyone know where I can get a proper locking stud that holds the starter in on a CA? The one with the tapered or pointed end. The 2nd CA I just bought just has a regular bolt in it.
Starter failed in it, so have to replace it and want to put a proper bolt back in. Also looking for a hand clutch handle if anyone has both they want to sell.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 7:01pm
I turned down a bolt for a neighbors tractor to make the taper on it ---- still working after 5 years for him.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 7:55pm
1952 CA13092
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 5:51am
The bolt had a screwdriver slot. Hard to get them to tighten up. Then folks noticed WC, and WDs had lots of these special Allis bolts with the hex head and used them. They are a special taper. I have a bin full of them.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 6:32am
hmm... maybe take it from your 1st CA ????LOL
OK, I ground a point on a regular bolt for one of my D-14s 10-12 years ago. It was fine. I think the 'trick' is to make the taper(pointy portion) a smaller taper than where it goes in.
Now if you do make a new bolt, make TWO ! That way BOTH CAs match !!! AND, you'll have a 'rare ,original' bolt as a spare.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 7:46am
Going to get Steve at B&B to rebuild my starter as soon as I get it shipped to him and he may have a bolt, but if not I'll buy one off you Lon if you want to sell one?
Last resort will be to get my local machine shop to make me a couple.
Or just buy a hand crank for CA #2, LOL
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 12:33pm
That bolt also uses a lock nut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 8:34pm
Yes, both of mine have a locknut on them. Just the recent purchased CA has a regular bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 6:44am
The bolts are for sale if you need one.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 8:28am
Jeeze, I'll have to look at my CA's and see what they have for starter retention. So far I've never had a starter problem with a 125. Have plenty of the WD style bolts around, somewhere.
