CA speed 1st and 2nd
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: CA speed 1st and 2nd
    Posted: 23 Mar 2024 at 3:48am
maximum speed of a allis CA in second gear
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2024 at 6:37am
As per the CA operators manual with 11.2X24 tires @ rated RPM (1650):
1st-1.94
2nd-3.41
3rd-4.36
Now with 13.6X24 tires that you have @ 1650:
1st-2.08
2nd-3.67
3rd-4.68
If you're running an engine speed of 2000RPM with 13.6X24 tires:
1st-2.51
2nd-4.44
3rd-5.94
 Many years ago when I started pulling a CA, I made up a speed chart with many different tires sizes and engine RPMs to figure out what size tires to switch to for what power I was making.
 D10/12 tractors will have the same speeds. As the D14/15 tractors and H3 crawlers used the same gearset. For H3 there was an optional set of gears that were faster in 1st gear. I looked for many years and never found that optional gear set
dgerth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2024 at 7:06am
Mr. Ken,
When I pull our CA, 1st is only for loading on the trailer. 2nd for everything else up to 8mph, then 3rd (?) depending on the track.
dan
