CA speed 1st and 2nd |
Ken in Texas
Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Topic: CA speed 1st and 2ndPosted: 23 Mar 2024 at 3:48am |
maximum speed of a allis CA in second gear
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 23 Mar 2024 at 6:37am |
As per the CA operators manual with 11.2X24 tires @ rated RPM (1650):
1st-1.94 2nd-3.41 3rd-4.36 Now with 13.6X24 tires that you have @ 1650: 1st-2.08 2nd-3.67 3rd-4.68 If you're running an engine speed of 2000RPM with 13.6X24 tires: 1st-2.51 2nd-4.44 3rd-5.94 Many years ago when I started pulling a CA, I made up a speed chart with many different tires sizes and engine RPMs to figure out what size tires to switch to for what power I was making. D10/12 tractors will have the same speeds. As the D14/15 tractors and H3 crawlers used the same gearset. For H3 there was an optional set of gears that were faster in 1st gear. I looked for many years and never found that optional gear set
dgerth
Posted: 24 Mar 2024 at 7:06am |
Mr. Ken,
When I pull our CA, 1st is only for loading on the trailer. 2nd for everything else up to 8mph, then 3rd (?) depending on the track. dan
