CA soot on hood |
racin69z
Joined: 11 Jan 2015 Location: Jackson mo Points: 43 |
Topic: CA soot on hoodPosted: 09 Feb 2017 at 1:47pm |
I have a 52 CA that I recently repainted. I installed a new stanley muffler with a rain flapper. I am getting a lot of soot on the hood. Before I painted the tractor it had a straight pipe with a turn out away from the tractor. I never recall getting soot on the hood, but the tractor looked so rough I may not have noticed.
I like the way it sounds now, but I need to get rid of the soot. Does anyone have any insight? Thanks Lynn
Dans 7080
Posted: 09 Feb 2017 at 1:51pm |
Put a turn out on the muffler would be the only solution.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1799 |
Posted: 09 Feb 2017 at 2:12pm |
May also wait until the "new" wears off the muffler?
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11158 |
Posted: 09 Feb 2017 at 2:37pm |
Run some fuel additive it might be from the great gas that we get now
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 09 Feb 2017 at 2:40pm |
Plus your carb. may be set a 1/4 to rich.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3086 |
Posted: 09 Feb 2017 at 2:48pm |
Stan R
Posted: 09 Feb 2017 at 3:00pm |
Minor leak at the muffler/ manifold connection?
racin69z
Posted: 09 Feb 2017 at 3:20pm |
Im pretty sure its coming out of the top. I will try a turn out.
Thanks Lynn
CTuckerNWIL
Posted: 09 Feb 2017 at 5:35pm |
Lean the mixture out a bit and run some Seafoam thru it. If there is soot coming out, there is soot inside for whatever reason.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54714 |
Posted: 09 Feb 2017 at 6:26pm |
If you don't run it very long, it might be condensation, carrying the soot out. Always run long enough to get to operating temp. Might also want a turn out on it, for running cold...
racin69z
Posted: 09 Feb 2017 at 11:42pm |
I have the marvel carb with only idle mixture adjustment. I will double check the adjustment. Has anyone ever found the need to run a smaller main jet on a stock engine?
racin69z
Posted: 09 Feb 2017 at 11:44pm |
One thing i have never touched is the timing. Its always started and ran good so i never fooled with it. I replaced the points condensor cap rotor plugs coil and wires just never adjusted the timing
TimNearFortWorth
Posted: 10 Feb 2017 at 5:46pm |
Nice lookin 45 there Dave, big rears and especially those big multi-ribs on the front really set her off.
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 11 Feb 2017 at 2:17am |
if it's kept outside, it'll do that
Brian Jasper co. Ia
Posted: 11 Feb 2017 at 8:39am |
Condensation. On a cool day with plenty of humidity it's going to happen for a minute or so until the muffler warms.
