CA Roll Bar?
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Roll Bar?
    Posted: 18 Aug 2023 at 3:56pm
Has anybody ever added a roll bar (and/or associated canopy) to a CA?  Where would you attach it?
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2023 at 4:08pm
does not answer your question.. but here is the actual testing on a Allis 190.
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2023 at 5:02pm
I had a square steel tubing frame and 2” angle iron bottom bolted to the platform rails inside of where the fenders are mounted.
Then got a fiberglass canopy from a golf cart for the top.
Do not have it anymore.
Definitely Not a Roll over protection device!
DeWayne
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2023 at 5:13pm
If you're wanting roll over protection, attach to the axle. If you want a sun shade...the fenders would work for that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2023 at 5:36pm
I was thinking that I could attach to my new drawbar supports that I'm making that attach to the cultivator brackets on the axles.  But they would have to bend to follow the shape of the fenders and might limit how far in the wheels can shift.  My new hydraulic remotes will be attached to the inside of the fender rails positioned vertically, I'm hoping.  Need to make some more measurements.
Edited by dfwallis - 19 Aug 2023 at 12:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2023 at 5:37pm
DeWayne
Cool, that looks fine...
