CA Rocker Arm Alignment
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Rocker Arm Alignment
    Posted: 17 Sep 2023 at 8:55pm
Nearing assembly stage for rebuilt 1952 CA engine (Crankshaft had to be returned for additional end play work).  I noticed that the rocker arms don't align very well with the valve stems.  They are too WIDE.  There are no shims/washers.  The rocker arm bushings themselves would have to be ground to achieve narrower spacing.  Some are misaligned by as much as 1/2 of the "button".  Apparently it's been that way for some time as there was considerable button wear which I've cleaned up.  I don't have the setup to grind these bushings "true".  Since it ran that way for 50 years (probably), should I worry or do I need to take it in for more head work (head was rebuilt, new valves, seats, springs). If I have to take it back to the machine shop, I'll have to suspend work until next May, probably, since I have to return home.  The rocker arm bushings extend beyond each side by between 1/16 and 1/8 inch (varies as they're not all pressed in identically or evenly).  I thought that maybe somebody assembled them in the wrong order, but that does not seem to be the case as none matched other valve positions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2023 at 10:59pm
I had a "B" with the same engine. Had a freeze plug failure.. Here is a photo of the rocker arm area.... You can see that the rockers do NOT fit the valves very good.. That is common on this engine.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2023 at 9:00am
I've been building engines for years and rocker arm bushings were always faced off flush with the rocker arm.  Never seen them left protruding past the edge of the rocker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2023 at 9:05am
Im not sure what you are going to "face off"... look at the FIRST rocker arm on the left.  it obviously sets about  1/8 inch to the LEFT of the valve stem center... the second rocker sets to the RIGHT of the valve stem center.... compare the rocker arm end to the spring cover and you can see the offset.
one thing to remember... AN auto engine puts out about 1 HP per cubic inch.... this engine puts out about 25 HP for 125 cubic inches... I agree it is not the BEST design... but seems to work for 75 years..
Edited by steve(ill) - 18 Sep 2023 at 9:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2023 at 9:12am
OK.. i understand what your saying.. Are the BUSHINGS original ? ... Thats my point.. Many are FLUSH and still the arms do not align to the stem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2023 at 9:42am
look about the 13 minute mark..........
Edited by steve(ill) - 18 Sep 2023 at 9:44am
This page was generated in 0.081 seconds.
