CA Rims
boilerpete View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote boilerpete Quote  Post ReplyReply Direct Link To This Post Topic: CA Rims
    Posted: 11 Sep 2024 at 10:36am
Working on restoring a 1950 CA.  Need a couple parts, hope someone can help.
Rims:  10x24 4 Rail.  Several vendors have them, most priced in the $450-$700 range.  There is a place in Bourbon Indiana, sort of near me so I wouldn't pay shipping, JC's Farm and Garden Supply, listed in Old Allis News, for only $326.  Anybody ever bought from them?  Seems odd that they'd be less than half price from Steiner's or DJ's.  Like the price but not if they're cheap or won't hold up.
Also, three of the four CA's rail clamps are the same as a WD or WD45, but one is different.  Part number 70225188.  Anyone know where I could find a couple of those?  Google is not my friend for that one.
Thanks in Advance.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2024 at 12:15pm
Confirmed 70225188 is the correct PN for the CA "body, guide, rail".  Tractor parts ASAP has in stock for $60
Sorry, my first search returned 229188 (google thinks close enough is good enough)
Edited by dfwallis - 11 Sep 2024 at 1:19pm
1952 CA13092
Blake_AllisMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2024 at 1:17pm
PM sent
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
1977 5020 4WD Serial Number 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2024 at 1:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2024 at 2:13pm
I believe that's where I got my 12x24 rims ($475 each including taxes).  I was pretty happy.
1952 CA13092
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2024 at 2:20pm
CA’s have only 3 clamps per side with 1 hanger clamp and the CA clamp bolts are square heads. W series have 4 clamps and the clamp bolts are hex heads.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2024 at 3:47pm
x2.  Clamps are not the same as those used on the WD or WD45.
Edited by DSeries4 - 11 Sep 2024 at 3:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2024 at 5:39pm
I guess I'll say that 70225188 is just the clamp shell/housing and doesn't include the innards.
1952 CA13092
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2024 at 8:56pm
I have purchased new 26" rims for my D-15 II from JC's. Only complaint is the slide rails only have 4 adjustment holes instead of 5 like originals.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2024 at 5:30am
JC's sells a lot of rims. They have a booth at most GOTO's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2024 at 10:08am
This part is the Guide Rail Body only.  It has NO hole for an eccentric pin.  It just holds the rim onto the wheel to help you get the rim on.
Do you have FOUR (4) clamps holding the rim onto the wheel?  Then you don't need anything.
As stated, the wheel and rim needs three (3) eccentrics (70220756) and one (1) GUIDE (70225188).  Also you need 3 of the BLOCK for Eccentric Pin, Rim Locking (70220032).
Do your eccentric pins have square heads or are they hexagons?  The square heads are made for the CA, but either will work.
HTHs....
This page was generated in 0.184 seconds.
