CA Remote Hydraulic Port
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Topic: CA Remote Hydraulic Port
    Posted: 02 Sep 2023 at 9:23pm
My CA has had a cap on the remote hydraulic port ever since I've had it. I need to run a remote cylinder now, and would like to know if the threads are 1/2" tapered pipe thread or are they 1/2" straight thread. Anyone know right off?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2023 at 10:22pm
i dont ever recall running into a straight thread on a tractor... I think all the hydraulic fittings are taper pipe.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2023 at 4:39pm
are you mesureing the hole size with a tape measure ? because 3/8 or 1/4 npt seems more inline to me
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2023 at 5:09pm
I’ve had several CA’s and 2 of them had capped outlets. I bought 2 Pioneer female couplers from Rural King and installed them and are working well after many years of service.
Edited by sparky - 03 Sep 2023 at 5:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2023 at 8:21pm
The reason I asked was that after installing the 1/2" NPTF coupler fitting, it leaked like a sieve. I've replaced many over the years  without any problems at all. I replaced a worn one on my WD45 last year and if memory is correct, it used a rubber washer and back-up nut. CA Parts Catalog shows a "ring, snap, coupler nose", P/N 224872 installed behind the coupler nose. Is that an o-ring?
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2023 at 9:28pm
Jim when I installed mine I just used Teflon tape. By the way I’m the guy who stopped by your place several years ago and picked up a single rear weight for a CA. Again, thanks.
This page was generated in 0.174 seconds.
