CA Rebuild - Got it Running
Dale (Stonelick) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Topic: CA Rebuild - Got it Running
    Posted: 31 Dec 2019 at 3:07pm
Finally got the 1951 CA running today with help from a golfing buddy.  Made adjustments to timing, rocker arm/push rod gap, and the carburetor main jet needle.  It runs really good!
Does anyone know correct torque for the head and rocker arm bolts?
Happy New Year.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2019 at 4:09pm
Bolt torques should be in the shop manual:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2019 at 7:24pm
You started the engine before torqueing the head to the proper spec.
Not a good idea.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 1:59pm
60lbs on the head. Do a Google search for Allis B head torque specs. It should show the tightening order also. Not sure about the rocker arms. I think I just snugged mine up. Oh and after you run it for a bit retorque.
Edited by mdm1 - 01 Jan 2020 at 2:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 7:58pm
mdm1:  Thanks for the information.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 8:42pm
Generally you run it up to full temp then let cool overnight and retorque cold.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 8:44pm
The spec for torque and a tightening sequence diagram are on page CA-24, top of the right column, in the manual Gerald J. posted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 7:28am
Jim.ME:  Thanks.  The manual from Gerald J. has more detailed information than the manual that came with my tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 10:34am
Dale,
 Awesome news! Thanks for the update!
We need pictures too!
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 12:40pm
Good to have a golfing buddy who knows engines!  You should let him win a few rounds. How is the oil pressure? Check that oil is getting to the rocker arm assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 1:21pm
Sugarmaker:  I had a You Tube video attached to original post.
BrianC: Oil pressure is good - now runs at 15 psi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 2:30pm
Dale,
Ok Went back and looked at the video! I am still learning about posting videos. Good job getting the tractor running. Yes torque that head. Not sure what was causing the smoke? Oil pressure sounds like good number.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 3:52pm
GREAT!!!  Always good for me to hear the B-C-CA engine run.  They are so dependable.
You might consider running the engine till hot.  Let cool.  Readjust the valve clearances.  We always did that.
As to the valve cover - and this is back in the day - 50's - we thoroughly cleaned the valve cover gasket area, cover and attachment area.  Put it upside down in a vice, attached the
gasket - we used shellac - I know there is better now, placed several heavy tools on the gasket to hold it in position, let sit for a while - 30 min.  Then attached to head.
Always had to be careful since there is a large span area.
Engine sounds so good.  Cannot tell you the memories it brings back.  Especially after an overhaul.
Good Luck!
Bill Long
