CA Power Steering
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Power Steering
    Posted: 08 Feb 2026 at 5:29pm
1952 CA13092
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2026 at 5:35pm
Trying to make it into something it was never intended to be!!
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2026 at 6:59pm
I have a CA wide front, not that hard to steer unless you spread it out for two row plowing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2026 at 7:34pm
My narrow front is slightly hard to steer with the front wheel weights on.  Don't really need them for the 3pt mower I think (580lbs).
1952 CA13092
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2026 at 6:16am
I have 2 WFE CA's, going to pass on this mod.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2026 at 7:20am
A good quality ball bearing spinner on the steering wheel would be a good start. Grease the spindles with the front end jacked up. 30 lbs of air in the front tires would also be beneficial. Turn the front tires around narrow and it will steer easier. OOOpps I guess you can't with the new fangled steering arm welded to the left spindle arm !!! seesh......
Cernunnos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cernunnos Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2026 at 7:49am
Even though that is not needed by me on my CA's, I do admire inventors and others that think outside the box, whether it is a great success or not.  Their ability to see a problem and come up with a solution is admirable. Thank you for posting the video.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2026 at 7:49am
I guess I have to give him a few points for trying but my goodness.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2026 at 3:27pm
Farm Show magazine had lots of stories like this, throughout the years, but I would never butcher a historic tractor like that...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2026 at 3:58pm
I didn't see him turn full left and right. I'm thinking that he doesn't have as many degrees of turning as the OEM was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2026 at 7:02am
Not exactly what one would call a 'clean install'!
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2026 at 8:38am
I am a modernizer. But holy smokes NO.
The power steering assist from an old Gleaner would have fit right on the steering arm and the only modification would have been the draglink then. This is way over complicated.
A future parts tractor was just made.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2026 at 9:48am
Originally posted by Nathan (SD) Nathan (SD) wrote:
The power steering assist from an old Gleaner would have fit right on the steering arm and the only modification would have been the draglink then...
Hmmm...SmileTongueWink
This page was generated in 0.262 seconds.
