CA pin couple swap to snap couple
super71bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote super71bee Quote  Post ReplyReply Direct Link To This Post Topic: CA pin couple swap to snap couple
    Posted: 15 Aug 2019 at 4:49pm
Hi everyone. I just started on this forum as I am new to the tractor world. I have been recently given a nice running 1951 Allis Chalmers CA, serial number "CA 635". My question is, can I upgrade the pin hook up to the newer snap coupler set up from another newer model CA? I want to use the tractor to pull some simple implements for working on my small deer food plot. The hydraulics work fine as I have already tested it. I know I could buy implements that will hook up to a ball on the draw bar but they are pricey and I sort of like the idea of using original parts. Thanks for whatever help you can give me.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2019 at 4:52pm
Hey welcome to another Wisconsinite. Sorry I can't answer your question but there are alot of knowledgable  helpful people here. Where in WI are you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 9:07am
Yes you can add the Snap Couple bell, but you have to alter the lift arms for the proper lift latches to fit.
 The pin hitch lift arms have a little "hangy down" piece with an extra hole, compared to the SC lift arms.
https://www.allischalmers.com/forum/uploads/101/CA_Snap_Coupler_Drawbar_Standard.jpg
Edited by CTuckerNWIL - 16 Aug 2019 at 9:09am
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 10:20am
I'd personally like the pin set up better
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 10:22am
I have a parts ca with all the snap coupler parts. Ryan 402-469-1738
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 10:44am
Why not just get a pin hitch 3pt adapter. I did and it worked great. I put the pin hitch back on later. The woods belly mower dosent work with a snap couple the bell gets in the way with a pin hitch I can have a hitch with the belly mower installed. I put the pin hitch adapter on one of my WEd 45s and it workes hreat there also
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 1:32pm
Don't need to cut down the lift arms. I use mine with both pin and snap coupler implements.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 4:52pm
 I thought the lift latches wouldn't fit right with the extra part on the bottom of the pin hitch lift arms.
Edited by CTuckerNWIL - 16 Aug 2019 at 5:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 9:11pm
They work well but they are a little loose and pivot on the bolt. Since I have both pin & Snap-Coupler equipment I have no need to cut the arms down. One benefit to leaving the arms long is have lift snap-coupler equipment a bit higher off the ground.
Thanks & God Bless
Dennis
