CA oil pump damage? |
J&J
Topic: CA oil pump damage?Posted: 16 hours 37 minutes ago at 7:20pm |
This is the oil pump body from a ca tractor 125 engine. You can see down in the bore where the rotor shaft rides is pretty scarred up, looks worse than it feels though, I assume there's no fixing it. Anyone have a good oil pump for a ca? I do have a new rotor kit coming. Thanks
![]() Edited by J&J - 1 hour 7 minutes ago at 10:50am |
Joined: 11 Sep 2009 Location: illinois Points: 89892 |
Posted: 3 hours 59 minutes ago at 7:58am |
how much clearance do you have between the shaft and the bore ? There looks like GROOVES in the bore ?? If minimal clearance, i would reuse and the groves might help lube the shaft ?? If you have excessive clearance, you could have it bored and a brass sleeve installed... but might be cheaper to find a USED PUMP and rebuild it..
several on e-bay for $40 - 75. Edited by steve(ill) - 3 hours 54 minutes ago at 8:03am |
