CA Oil Pickup Strainer
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Oil Pickup Strainer
    Posted: 24 Sep 2023 at 6:35pm
Hi, two questions about the oil pickup strainer...1) It appears to be just press fit in and seems like it could easily come out.  Should there be some additional hardware to keep it in place like a clip or should I bend the lip a little?  2) The inside end is open.  Since it doesn't fit snug against the wall, this could allow oil to go around the strainer rather than through the mesh (although unlikely if the strainer is clear).  Should the end be capped off?  I could wire an additional screen or cap to it.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2023 at 7:03pm
JB weld it into place... the other end should be closed.... wire screen soldered over the hole.
Edited by steve(ill) - 24 Sep 2023 at 7:06pm
Lon(MN) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 7:32am
There was a special clip that held the screen in place. I use mechanics wire. Couple turns around the end and across the screen. It can be removed and cleaned as it was designed.
http://lonsallischalmers.com
This page was generated in 0.073 seconds.
