CA No Manifold Gasket?
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: CA No Manifold Gasket?
    Posted: 13 Feb 2026 at 8:24am
In another thread I mentioned that my CA had no evidence of there ever having been a rear main oil seal in it, well, my Grandson pulled the manifold off to put a new one on and lo and behold, there was no manifold gasket whatsoever! just a film of blue RTV silicone. Yikes!
Two of the exhaust ports showed slight leakage but the intakes appeared to be sealed nicely. It ran well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2026 at 8:38am
Back in the 70s I've knew racers and old time SuperStock pullers that used RTV for manifold gaskets. When I first heard about it, I thought: No that can't work, but it does. With the removal of asbestos from the manifold gaskets, I always use some Red RTV around the port holes. That is the only thing that I've found to make the new type manifold gaskets last more than a few years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2026 at 10:10am
Ford built literally millions of engines with no exhaust manifold gaskets, but this is the first time I have seen an engine with no gasket on the intake.
