CA loose steering |
DCAC
Joined: 20 Oct 2018 Location: east central SD Points: 527 |
Topic: CA loose steeringPosted: 16 hours 60 minutes ago at 6:13am |
Hello everyone, my CA is back under its own power again and everything seems to be in good shape so far except for the loose steering, it keeps one on their toes in 4th gear! I did a search on here about the problem but didn't find anything. Did the same on Yesterday's Tractors and I did find a post there from back in May 2018, mentioning a pawl that engages the worm gear that gets worn, and that it was perhaps available from Deere. Is this pawl available from them or Agco? Would anyone have part numbers, or does one have to be made? Are there any adjustments I could try in the steering boxes?
Thanks for any help and advice,
Joined: 11 Sep 2009 Location: illinois Points: 90676 |
Posted: 14 hours 17 minutes ago at 8:56am |
when your driving down the road , you can move the steering wheel 20 or 30 degrees in each direction and there is no movement of the steering arm on the gear box below the gas tank ??? If so, that is the PAWL problem you speak of... If the arm moves and the SLOP is in the front end under the radiator, thats different..
DCAC
Posted: 2 hours 51 minutes ago at 8:22pm |
When going down the road at high throttle, it wanders considerably. The most play is in the front gear box under the gas tank, there is some play in the front one as well, but not as much.
