CA Lift will not lower
BV 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BV 2 Quote  Post ReplyReply Direct Link To This Post Topic: CA Lift will not lower
    Posted: 28 May 2010 at 10:15am
The lift on my ca is stuck in the up position and will not lower? Any tricks to this, thanks BV 2
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 10:29am
Check the linkage first to be certain it is properly adjusted.  Check the bottle valve on the top of the pump to be sure it is connectred and moving.  Be certain the plates are working together.  Then on the hyd pump there is a screw closest to the front - I do not know the letter - screw it in slowly.  It controls the valve rack.  May help.
Let us know how it goes.
Good Luck!
Bill Long
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 10:36am
Happened to me once too. Stayed up for 2 wks at full trapped pressure. You might try loosening a cyl hose to relieve pressure and possibly return system to normal.
BV 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BV 2 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 7:07am
Thanks guys for the infomation, when inspecting the bottle valve i found the ball was missing, blead the lines and started working. Thanks again for the help
