CA hydraulic pump
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Topic: CA hydraulic pump
    Posted: 09 Mar 2010 at 8:02pm
I've had my Hyd pump apart three times. evry time I put it back it will lift the loader up and then I put the loader down it won't go up again. the pump works good. I put new piston springs and a control valve spring in it. this last time  I found the pin in the drawbar lockout lever was broken. so I changed it. same thing. If I take the drawbar control section off don't change anything and reinstall it then it works one time and stops again. Any ideas whats wrong?
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2010 at 5:45am
Dave is your fluid level full, it will take a couple extra qts of hyd fluid to run a loader on the ca. Sometimes the balls can get out of round and will not seal properly, agco still sells them really cheap. Ron
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2010 at 6:39am
The fluid is full and the check balls are perfect. The hand lever dosen't feel rigtht after I cycle it from up to down.  I'm taking the Draw bar controll off again today  to see Why its not operating the control valve.
This page was generated in 0.042 seconds.
