ca hydralic oil |
rilenz ![]() Bronze Level ![]() ![]() Joined: 23 Dec 2022 Location: WI Points: 67 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Jan 2024 at 1:03pm |
I added a loader to my CA and a 6 ft. back blade. My question is do I raise both items to the max and then top off the oil level.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87899 |
normally you fill with both implements setting on the ground in the rest position... Operated them both up and down to make sure the cylinders are purged of air.. then set on ground and fill.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24697 |
hmm, my D-14 says to raise it up THEN check the level...... it's stamped on the measuring stick.... see, guys DO read somethings, sometimes !!!!
it makes sense to me to have hydralics rested other wise where would the extra oil go
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Utopia Points: 2458 |
I've seen it both ways myself. Many times on tractor implements they want the cylinders fully stroked and the reservoir level brought to the marks. Seems backwards to me unless they are sizing the reservoir just large enough for the purpose in space constraints.
That's All Folks!
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5107 |
If you had the operators manual for the CA tractor, you would find it reads: Have the tractor rams Extended and the Loader Bucket Resting on the ground. Fill Hydraulic system to the FULL mark on the bayonet gauge and then add ONE extra quart of oil.
For any piece of equipment that you wish to operate and care for correctly, you should have an owners manual.
I do have a couple CA manuel but did not see that part so I thought I would check here did'nt mean to bother you
AC WD45 ![]() Orange Level ![]() ![]() Joined: 28 Sep 2009 Location: Mid Michigan Points: 2060 |
You're not bothering anybody. Some of the old cogers claround here can be quite testy. They seem to forget we were all new to equipment at one time or another and they seem to think they need to get all fired up at new guys. And seem to forget, some of these old manuals, especially for loaders can be extremely hard to find after 60+ years. Get yourself a manual and read it thoroughly, and don't let anyone scare you away from asking a question. |
German Shepherd dad
Yep, that's right Paul, everyone has or knows where to get owners manuals for attachments most people scrapped 20 years ago. Good grief, I don't think the additude is necessary. Give the guy a break. Edited by AC WD45 - 16 Jan 2024 at 9:26am |
German Shepherd dad
dfwallis ![]() Orange Level ![]() Joined: 09 Mar 2023 Location: DFW Points: 810 |
I don't have any documentation for a loader, but the base manual says to check oil with the lift arms extended (top it off). It also says that on the dip stick.
1952 CA13092
Thanks for the info everybody
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2221 |
This is one revision of the manual for a CA8 loader.
MadCow ![]() Bronze Level ![]() Joined: 27 Aug 2023 Location: South Dakota Points: 126 |
I have a loader on my D15. I raise all my arms up, bucket as high as it'll go. (Like 48" stroke in 1 1/2" bore) and fill to the bottom line. Then drop it all to the bottom. Usually get a little coming out the fill of I use it hard right away. And the leaks in the system usually set it right soon enough and I'm off to the races.
