Ca headlight mounting? |
   Lincoln
      Quote   Reply
     Topic: Ca headlight mounting?Posted: 13 Apr 2010 at 7:35pm  |
   I have a 1951 CA that has been redone. I do not know where the headlights mount. If someone can show a picture that would be great.
  thanks in advance
   CTuckerNWIL
   Joined: 11 Sep 2009 Location: NW Illinois Points: 22825  |
      Quote   Reply
     Posted: 13 Apr 2010 at 8:32pm |
There should be a half inch or so hole in the hood and front shroud where they overlap, maybe 4 inches down from the top of the hood. The lights mount in these holes. Here is a picture of somebodies CA with lights.
  ![]() Edited by CTuckerNWIL - 13 Apr 2010 at 8:36pm  |
  Lena 1935 WC12xxx, Willie 1951 CA6xx Dad bought new, 1954WD45 PS, 1960 D17 NF  |
   RoyR (MI)
   Joined: 12 Sep 2009 Location: Reading, MI Points: 10  |
      Quote   Reply
     Posted: 13 Apr 2010 at 8:33pm |
   There should be a hole on each side where the hood and the radiator shroud meet.  The lights have a mounting stud that fastens in the hole.
  Roy
   Rick of HopeIN
   Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1329  |
      Quote   Reply
     Posted: 13 Apr 2010 at 8:50pm |
   The holes thru hood and front shroud are oversized in that one spot to accept a light at each side.   Same setup as used on the B and C tractors.
   Cal
   Joined: 14 Sep 2009 Location: East Woodstock Points: 174  |
      Quote   Reply
     Posted: 13 Apr 2010 at 9:38pm |
   The original lights have a wire that runs thru the center of the stud that mounts the light to the tractor. The 1/2 inch hole should be a threaded insert to screw the headlight into the radiator shrould. Cal in Ct.
   Brian Jasper co. Ia
   Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508  |
      Quote   Reply
     Posted: 14 Apr 2010 at 12:14pm |
   Yep, the lights thread into the radiator shroud and there are a couple holes with rubber grommits in them for the wires to pass through.
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
