CA Hand Clutch |
Les Kerf
Topic: CA Hand ClutchPosted: 05 Nov 2025 at 7:44pm |
Pulled the hand clutch from the CA today, it is well lubricated ![]() ![]() |
CA13414
Posted: 06 Nov 2025 at 7:53pm |
That is indeed well lubricated!!!!
A mess of leaking oil and years of organic material. Our was full of corn shucks and grime was packed in like a bird nest. All the oil and worn down springs and clutch plate = slipping. At least yours was one unit. Some or our trouble was because the hand clutch was not bolted to the brake unit and loose (all 6 bolts were sheered off). Thus, was the source of noise and failure to disengage and re-engage. |
Les Kerf
Posted: 07 Nov 2025 at 7:11am |
The surprising thing is that the clutch wasn't slipping and seemed to function correctly in all respects. Granted, we never worked it very hard either; this is the tractor that I purchased earlier this year for cheap and have been tinkering on ever since. The main clutch is worn out so we have it split and both final drives are off; an unrelated semi-emergency developed with my Son-in-law's truck that requires shop space so the CA is now shoved to the side for the duration.
Chaimers
Joined: 23 Jun 2020 Location: Pennsylvania Points: 30 |
Posted: 17 Nov 2025 at 6:10pm |
If you have it tore down that far did you give it any thought about putting the hand clutch on the left side? I feel it should have been over there from factory. JMO
Les Kerf
Posted: 17 Nov 2025 at 7:05pm |
Yup, as a matter of fact, Grandson and I have already made that decision in order to be able to run the hydraulics at the same time as releasing the hand clutch. Not quite sure what we will use to steer with, knees, perhaps?
rilenz
Posted: 18 Nov 2025 at 5:27am |
I always wanted to move the clutch to the other side. But didn't think it was possible . Is it a real problem or more or less switching axle and clutch parts side to side?
Les Kerf
Posted: 18 Nov 2025 at 5:43am |
We have yet to complete this project, but I have read several threads about this, and all indications that I can see since opening up the tractor appear to be 'just' a matter of switching components. "Nuthin' to it but to do it" ![]() I fully intend to post updates as we make progress.
rilenz
Posted: 18 Nov 2025 at 5:49am |
will definitely be on the lookout for your progress and hopefully attempt the task after the winter plowing I do with my ac ca
Les Kerf
Posted: 18 Nov 2025 at 12:57pm |
I opened up the Lambert clutch today, at a bare minimum it is in need of new clutch linings, re-surfacing the pressure plates would probably be advisable. Also, the brake drum surface is heavily worn. I am open to suggestions
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5170 |
Posted: 18 Nov 2025 at 1:59pm |
Check with Rick Corder. That clutch disc uses the exact same lining as a certain hated color tractor's brake disc. He's not doing clutches any more, but he just may reline that disc for you.
If he won't I could reline your disc. Edited by PaulB - 18 Nov 2025 at 2:00pm |
Les Kerf
Posted: Yesterday at 6:33am |
Thanks Paul, I may need to take you up on that offer, Rick was pretty adamant when announced that he was quitting the clutch business.
rilenz
Thanks(1)
Posted: 6 hours 50 minutes ago at 8:18am |
Hey Les according to a fellow on here he used a piece of DOM pipe
Les Kerf
Posted: 6 hours 23 minutes ago at 8:45am |
That would likely be the easiest way to facilitate sleeving.
