CA Hand Clutch
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: CA Hand Clutch
    Posted: 05 Nov 2025 at 7:44pm
Pulled the hand clutch from the CA today, it is well lubricated Tongue
CA13414 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2025 at 7:53pm
That is indeed well lubricated!!!!
A mess of leaking oil and years of organic material. Our was full of corn shucks and grime was packed in like a bird nest. All the oil and worn down springs and clutch plate = slipping.
At least yours was one unit. Some or our trouble was because the hand clutch was not bolted to the brake unit and loose (all 6 bolts were sheered off). Thus, was the source of noise and failure to disengage and re-engage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2025 at 7:11am
The surprising thing is that the clutch wasn't slipping and seemed to function correctly in all respects. Granted, we never worked it very hard either; this is the tractor that I purchased earlier this year for cheap and have been tinkering on ever since.
The main clutch is worn out so we have it split and both final drives are off; an unrelated semi-emergency developed with my Son-in-law's truck that requires shop space so the CA is now shoved to the side for the duration.
Chaimers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chaimers Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 6:10pm
If you have it tore down that far did you give it any thought about putting the hand clutch on the left side? I feel it should have been over there from factory. JMO
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 7:05pm
Yup, as a matter of fact, Grandson and I have already made that decision in order to be able to run the hydraulics at the same time as releasing the hand clutch. Not quite sure what we will use to steer with, knees, perhaps? Tongue
rilenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:27am
I always wanted to move the clutch to the other side. But didn't think it was possible . Is it a real problem or more or less switching axle and clutch parts side to side?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:43am
We have yet to complete this project, but I have read several threads about this, and all indications that I can see since opening up the tractor appear to be 'just' a matter of switching components. "Nuthin' to it but to do it" Wink
I fully intend to post updates as we make progress.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:49am
will definitely be on the lookout for your progress and hopefully attempt the task after the winter plowing I do with my ac ca
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 47 minutes ago at 12:57pm
I opened up the Lambert clutch today, at a bare minimum it is in need of new clutch linings, re-surfacing the pressure plates would probably be advisable. Also, the brake drum surface is heavily worn.
I am open to suggestions Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 45 minutes ago at 1:59pm
Check with Rick Corder. That clutch disc uses the exact same lining as a certain hated color tractor's brake disc. He's not doing clutches any more, but he just may reline that disc for you.
If he won't I could reline your disc.
Edited by PaulB - 18 hours 44 minutes ago at 2:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 11 minutes ago at 6:33am
Thanks Paul, I may need to take you up on that offer, Rick was pretty adamant when announced that he was quitting the clutch business.
