CA Hand Clutch Slip
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: CA Hand Clutch Slip
    Posted: 22 Mar 2014 at 2:15pm
Well had my first hook today with the CA and I didn't even get off the line as the hand clutch was slipping.
I searched but heck if I can find the older threads on what to do.
If rebuilt will it hold (Stock HP, up to 3500 lb)?
Or replace it with a solid shaft?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2014 at 4:27pm
Here ya go. any time I want to find an old post, I do a google search. This one, I searched for "Allis Chalmers CA hand Clutch rebuild"
http://www.allischalmers.com/forum/forum_posts.asp?TID=12753&title=allis-ca-hand-clutch-rebuild
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2014 at 4:29pm
The hand clutch should handle anything a stock engine can muster but if pulling is the main use of your CA, you might wanna look for an axle from the left side of a donor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2014 at 4:33pm
I found a shaft, I guess that looks to be the easiest solution for my needs. Don't have a use for the hand clutch right now
Charlie
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2014 at 7:47pm
You will need a brake drum too. The old brake drum is part of the clutch. Pretty easy to swap the clutched axle out for a solid one in.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2014 at 8:07pm
If re-done proper it will hold just fine, leave it stock, unless you gotta 160 under the tine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2014 at 9:24am
I thought that if you removed the clutch portion from the brake drum, you could still retain that drum with a longer axle?
Charlie
This page was generated in 0.093 seconds.
