CA Hand Clutch Seal Question |
dfwallis
Topic: CA Hand Clutch Seal QuestionPosted: 12 Jun 2024 at 6:30pm |
I'll be working on the hand clutch soon and I'm wondering if I should pre-order any seals. Of course I'm hoping its all there and in good working order otherwise. There are no apparent seal leaks that I can see in any of the inspection holes. What about:
70206449 (2), 70230851 (2), 70232186? (final drive/axel, final drive clutch sections)
1952 CA13092
Joined: 11 Sep 2009 Location: illinois Points: 88649 |
Thanks(1)
Posted: 12 Jun 2024 at 9:59pm |
If your tearing down a 70 year old tractor, i would definitely put new seals.. Probably be old and cracked even if they dont leak..
dfwallis
Posted: 13 Jun 2024 at 12:49pm |
I ordered the seals. I just hope and pray there's nothing else seriously wrong :(
Symptoms: Weak spring force only from aft to mid handle position. You can manually move the handle from there forward with only a little resistance. Appears there is enough engagement to move the tractor but unsure yet about actually pulling something.
1952 CA13092
