CA Hand Clutch Pilot Bushing\bearing
Turbo_760 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo_760 Quote  Post ReplyReply Direct Link To This Post Topic: CA Hand Clutch Pilot Bushing\bearing
    Posted: 03 Apr 2017 at 7:29am
I am now starting to put the hand clutch back together but I can not recall which is the correct pilot bushing (took it apart a few years ago). I have 2 different bushing with the same OD and ID (both fit into the bore) except one has a flange on it.
Which one is the correct bushing?
here is the bore in handclutch where the bushing goes
1951 CA
Cub Cadet 149
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo_760 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 12:12am
Anyone recall who has re built a hand clutch which one to use
1951 CA
Cub Cadet 149
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 4:18am
The one without the flange is what I always see in the hand clutches.    Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo_760 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 7:22am
Rick, I really appreciate you input! I'll follow suit and use that one to.
1951 CA
Cub Cadet 149
