CA Governor Shaft Loose |
CA52
Joined: 01 May 2016 Location: N. Illinios Points: 11 |
Topic: CA Governor Shaft LoosePosted: 20 Mar 2017 at 12:10pm |
I was inspecting the oil lines going to the governor on my CA, and noticed the shaft coming out the top where the oil ling goes in is loose. It wiggles some and I can pull it straight up a 1/4" or so and see splines. What am I looking at to fix this?
Thanks for any help |
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 20 Mar 2017 at 3:41pm |
Red locktite is one way. You want to clean the oil off both the hole and pin first. If the hole is really sloppy JB Weld will work also.
Edited by Dick L - 20 Mar 2017 at 3:43pm |
rpropst
Posted: 20 Mar 2017 at 4:07pm |
x2 on JB weld.
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 20 Mar 2017 at 8:18pm |
I have 3 of them on C tractors that are the same way! thanks; ac fleet
Posted: 20 Mar 2017 at 9:30pm |
Pull it out and use a center punch all the way around it to make it look like a golf ball. Clean and use RED Loctite and allow to cure.
CA52
Posted: 21 Mar 2017 at 9:17am |
Sounds like a plan! Thanks for the help all!
