CA governor oil line
AndrewJS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewJS Quote  Post ReplyReply Direct Link To This Post Topic: CA governor oil line
    Posted: 02 Jan 2022 at 3:40pm
Hi all,
I have been having a problem with my 1954 CA lately where the oil line (actually two separate lines converging into a T) going into the top of the governor keeps popping out when I adjust the throttle. I'm not sure if the fitting on the end of the line is bad, or if I am missing a part. Is there supposed to be an o-ring or something on the end? I have included a picture -- you can see the whole governor is wet as this was taken after I popped the line back in after it had been leaking for a bit. Any help would be greatly appreciated!
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 4:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 4:57pm
pretty sure it'd be a 'compression' style fitting.Maybe the brass insert is missing ??
kinda curious about the blue 'undercolor'...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 7:38pm
Is it the famous missing blue, from someone's ford emblem?Wink
Anyway as Jay said, might be a worn out, cracked, or missing brass ferrule...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 8:01pm
Are you saying one of the small lines is popping off or the metal stand pipe, below the tee, the linkage pivots on is popping out of the housing? I am thinking it sounds like you are talking about the stand pipe coming out of the housing.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 8:07pm
The top nut? Maybe an optical illusion but that nut looks like it is cracked. If so, a new nut and ferrule are needed and maybe trim back the line just past old ferrule. Also check threads on the body of the fitting
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 8:48pm
The first thing you might want to look at is to see if the T is turning as you move the throttle lever.  If that happens that can explain why oil is leaking - the moving of the T can wreck the ferule on the line that comes out of the side.  I had that same problem on my D15 several years ago.  The T and governor linkage were rusted together.  Took everything apart, cleaned up, reassembled and has not had a problem since.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewJS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 11:09pm
Yeah, I mean the standpipe coming out of the housing. Will look to see if I can find a replacement ferrule.
I am also curious now that another poster mentioned it, is the blue not normal for allis tractors? I thought it was a primer or undercoat for the orange. It's everywhere on this tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2022 at 4:55am
Blue is definitely not normal primer.  AC used a yellow primer on motor and castings. Also, look at the blue overspray on the radiator, from the factory, there would only be black paint, on the radiator...Wink
Edited by DiyDave - 03 Jan 2022 at 6:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2022 at 5:56am
The standpipe (actually called pivot pin in the parts book) is supposed to be a pressed in fit in the housing as far as I know.  No ferrule or threads at the housing end, at least on the one that came out on me.  You can try removing the linkage and oil lines.  Remove the pipe/pin and with a sharp prick punch make a number of punch dimples in the area that goes into the housing.  Clean/degrease that area on the pipe/pin and the hole in the housing.  Reinstall the pipe/pin using some Loctite bearing retainer or Loctite 660 Quick Metal on the dimpled surface of the pipe/pin and tap it into the hole.  Let it cure before reassembling the linkage and lines.
I have done this before, but someone may be along with a better method.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2022 at 8:04am
I have rebuilt several covers with this problem and I have a few for sale if interested. It has a new pivot shaft that is threaded into the cover. lselkriver@gmail.com
http://lonsallischalmers.com
Straanger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Straanger Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2022 at 10:23am
Someone probably painted it that color for a parade or something. In 1976 some locals got drunk and painted their tractors for the bicentennial parade. A red John Deere, white Farmall, and the blue Allis Chalmers WD that we ended up owning about 15 years later. And no, we didn’t re-paint the WD. We changed the oil, and sent it to the field to rake hay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2022 at 6:36pm
Also could be a municipality/gov't/golf course's colors...  Lots can happen in 60-70 years...Wink
This page was generated in 0.049 seconds.
