CA gas tabk
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Topic: CA gas tabk
    Posted: 24 Jan 2026 at 2:44pm
Does the B,C share the same tank as the CA?
OldAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldAC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2026 at 2:54pm
Close but the CA is a little different. has a factory clearance 'ding' in the bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2026 at 2:56pm
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2026 at 7:49am
Later model Bs also had the dent in the bottom of the gas tank to match with the starter switch on top of the starter.
 All C tractors and early Bs have the starter with the switch on the bottom.
Edited by PaulB - 25 Jan 2026 at 7:50am
