CA Fuel tank
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Topic: CA Fuel tank
    Posted: 17 Jul 2019 at 1:08am
Hi does anybody know if a new Fuel tank is available for a CA model Allis ?
Regards steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 7:11am
The simple answer, no.  Lots of good solid ones out there, but you'll need to clean it up good.  Some guys line them and I think that most don't.  As long as it is good and clean and kept full, there isn't any chance for rust to form.
Is this a working tractor or a showpiece?
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 8:13am
Thanks for the reply Ted , my tank has some big holes where the hold down strap is its not repairable i hav thought about cutting in half and putting another tank inside it and putting it back together so it still looks as it should ! I don't think i will find another tank down under
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 10:38am
Holes in the tank don't make it "not repairable". If  a good used one is not available, the thin weak spot can be cut out and a new piece of steel welded in place, just like guys do with rusted out rear rims.
 Being the penny pincher I am, I fixed a gas tank on an old JD tractor one time, that had a hole big enough for a small cat to crawl thru.Wink
ORBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ORBill Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 3:11pm
Steve
Sent you a PM
I'm headed "down under" soon and have a good tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 9:18am
Bill......Thumbs UpThumbs UpThumbs UpThumbs UpThumbs UpClapClapClap
This page was generated in 0.095 seconds.
