CA front weight |
bigredneck61088
Topic: CA front weightPosted: 05 Apr 2018 at 5:13pm |
How are you guys holding down the front of your CAs? Mine needs some weight and I have access to some suitcase weights, anyone build a bracket for those on a CA? Or would I be better off with front wheel or side weights. I have new tires and tubes in the front so they could be filled, but didn’t think that would make much difference.
Thanks in advance! |
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5181 |
Posted: 05 Apr 2018 at 6:40pm |
I've got front wheel weights and they'll help a little but not a whole lot. Those engine weights are pretty hard to find
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3200 |
Posted: 05 Apr 2018 at 7:05pm |
Pretty easy to modify a JD garden tractor weight bracket to bolt onto the front cultivator
mounts to use suitcase weights.Nice thing about suitcase weights is they are easy to take on and off as needed. |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 06 Apr 2018 at 4:03am |
Have you added a 3 pt? Most any of the factory equipment can be balanced with a pair of side weight and if needed a set of wheel weight. If you installed one of those aftermarket 3pt kit, you need to find anything heavy that is available. Maybe a seat out front for the MIL
bigredneck61088
Posted: 06 Apr 2018 at 7:27am |
Gary, got any pictures of one modified, sounds like a good option...
Paul, still on the factory AC gear, but moving snow with a AC blade I could use some steering weight... |
Gary Burnett
Posted: 06 Apr 2018 at 8:04am |
No pictures but really all that needs to be done is maybe drill a hole or two to line up with the CA depending on the bracket.I don't know which JD garden tractors my weight brackets came off as a friend of mine had a pallet of them and gave me several.Some were wider than others.They are well made heavy duty brackets. |
bigredneck61088
Posted: 06 Apr 2018 at 4:34pm |
I just checked ebay there are a million different John deer mounts, is it the front mount or rear?
Gary Burnett
Posted: 06 Apr 2018 at 7:13pm |
THe ones I have were front mounts
Rayhowling
Posted: 07 Apr 2018 at 8:10pm |
On my CA I welded a piece of steel 6 inchs long by 1/2 inch to the top of the axle with a small piece of steel welded on top of the 6 inch piece to keep the suitcase wts from moving sideways. I just use them when the rototiller is being used, it is easy to take wts off.
