CA Front Tires
Mike(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(GA) Quote  Post ReplyReply Direct Link To This Post Topic: CA Front Tires
    Posted: 10 Jan 2011 at 2:14pm
I have decided to go to 12-4 tires on the rear of my CA.  I was thinking of going to a larger front tire.   Has anyone put larger front tires on thier CA?  What rims have you been able to use?  Also, somewhere I saw three rib front tires were all three ribs were the same size.  Most three ribs I have seen have the middle rib larger for better turning.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 3:05pm
You might try 5.00x15 implement tires rather than the tractor type 3 ribs. If you want something other than tractor tires, I like either 165x15 radials or 5.60x15 bias tires that were used on the "old" VW Beetles. Kip
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 4:14pm
If you have a narrow front CA 15" wider tires may touch at the bottom. I think 5x15 tri ribs are OK. I have a junker C with car tires that touch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 7:18pm
Should have mentioned my CA has a wide front end.  Thanks.
