CA erratic spark
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 6:18am
Thanks for the explanation Steve B !!
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:40am
No problem! I know a lot of us here are like me. Wondering what took place with stuff that doesn't work right and what the correction was. Sometimes we don't always hear the outcome of an issue. Makes ya wanna' know in case that particular issue happens to you. I've been doing this type of work for over 50 years, and every once in a while you come across something goofy and you say to yourself "what the h*ll??  Of all the Distributors I've done over the years, I've only changed a few cam assys. A couple were in Automobiles due to higher rpm ranges.  Les is right. You don't need a 40K volt Coil. The standard Coils work fine unless you want to put one in. Not neccessary... BTW, I think the main reason why the one lobe wore out was lack of lubricant. The cam was dry as a bone, and the wick was there for the ride. Wasn't even touching the cam.
Steve@B&B
Edited by Steve in NJ - Yesterday at 10:43am
