CA erratic spark
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA erratic spark
    Posted: 11 May 2025 at 3:33pm
Analyzing spark via a gtc505 analyzer. All 4 cylinders look horrible. Cylinder 1 and 4 have the best signals but 2 and 3 are spiking randomly. All have a peak voltage of around 6kv, but 2 and 3 have extra random spikes to 9kv. Suspect random short circuit through cap or wires or other...all is new. My brother says it behaved the same in the 80s. It is running better with new venturi in carb, corrected spark plug gaps. I think to get higher spikes, the dwell time must randomly increase??   Does not seem to be any side to side distributor play, but there is up and down (in/out) play. Suggestions?
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 3:36pm
i always suspect a weak condenser or coil when i have problems..
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 3:52pm
Last electrical tune-up was in the 80's? I'd throw in new points, condenser, wires, cap and rotor in it. And go from there if still problematic. I'm sure your time is worth more than the cost of these items.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 4:18pm
Distributor shaft float? Yep, I’ve seen that a dozen times on old CA tractors. That’s your gremlin right there. New cap, new wires won’t fix it till you take out the slack. Re-bush or swap that dizzy
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 4:48pm
Stanr...Those are all new...completeish rebuild...from the waveforms, I think the coil is fine. I think more likely erratic points...the analyzer also gets confused with lots of extra pulses, declaring rpm 5000 instead of 1040 momentarily...cylinder 2 and 3 mostly.
Edited by dfwallis - 11 May 2025 at 4:55pm
1952 CA13092
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 4:59pm
I am not familiar with that analyzer, is it an actual oscilloscope?
Please describe "horrible". Is this at idle?
Do you mean that there are additional spikes other than the one, correct voltage spike?
When the points open, the electro-magnetic field in the coil collapses; the resulting 'flyback effect' induces a voltage in the secondary windings of the coil. This voltage increases until the spark is able to jump the gap. It is not unusual to have variations in the firing voltage as an engine runs; I would not be alarmed seeing 6-9kV ranges.
... I think to get higher spikes, the dwell time must randomly increase?? ...
No.
The required firing voltage was higher on that particular event. In order to fire at all, the dwell had to be at least 'adequate'.
The first two things I would want to know is what each cylinder has for compression, and next would be to hook up a vacuum gauge and see what that looks like.
Also, do you have any way to take analyzer readings under load? That would be most interesting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 5:04pm
You posted this while I was composing my previous answer.
Your points might be bouncing around, also poor grounding can give fits. The breaker plate needs to be well-grounded to the outside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 5:22pm
All speeds.
I suspect these are additional spikes because the analyzer thinks the rpm jumps from 1040 to 5000.
Yes, I have a masters in electronics.
No.
Cylinder 1 and 4 do not experience the additional spikes to 9k or more at all. Gtc505 is a scope of sorts. I have images but too painful to edit and upload on android.
Edited by dfwallis - 11 May 2025 at 5:24pm
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 8:43pm
...   Does not seem to be any side to side distributor play, but there is up and down (in/out) play...
After ponderizing about this for a while I believe jaybmiller is right. The vertical play in the distributor shaft can make the points chatter about due to the spiral gears causing the shaft to advance and return rapidly.
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 9:26pm
I had problems with my B, thought it was points, then change the coil and the cap, lastly replaced the condenser and that fixed my problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 4:43am
Check the insulator block that carries the points wire through the side of the distributor for cracks, and to see if the points wire has one ear grounding the points at that point...
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 7:29am
I will check...there was a grounding issue that I fixed...got shocked adjusting timing while running, touching the housing, but did not change the behavior when I fixed the grounding (paint).
I did check that the points plate is grounded.
Edited by dfwallis - 12 May 2025 at 7:36am
1952 CA13092
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 8:54am
What are the run symptoms from this? Spluttering/missing randomly?
I've not scoped the signal but believe I'm having a similar issue on the redneck B & (timing "fluttering" all over the place due to slack in it's ignition timing chain setup, needs a new bit of chain. So could be caused by the lash in your distributor in your case
Also, if the condenser is new new & not NOS then perhaps switch back to the previous one/a known good one. Modern parts are/were trash last I checked.
Edited by ekjdm14 - 12 May 2025 at 8:55am
Stuck Farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 9:24am
Sorry for posting inside the quote...android ui sucks
Runs perfect for short bursts, then random misfires. Also seems to be some sort of cyclical change to timing once every few seconds...engine slows slightly similar to what occurs when you retard timing, then goes back to normal. This is only noticeable if you set timing to extra retard to begin with.
Edited by dfwallis - 12 May 2025 at 9:26am
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 9:55am
Not a problem, posting from a 'phone must be a real PITA! This is kinda like mine now I think about it, acts like it was going to clear up and then back to misbehaving. thought I was losing fuel initially but pretty sure it's timing slop.
Would certainly attend to the distributor on your tractor, especially as Jay has experience of this being a cause.
Stuck Farmer
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 2:42pm
I would check the play or displacement in the distributor shaft, possibly worn main shaft bushings?  ~ Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2025 at 1:54pm
I took the distributor apart and gave it a thorough cleaning. I didn't have a rebushing kit so stopped there. There is some marginal improvement...the centrifugal mechanism was highly gunked up, but only improved the advance/retard process...cylinder 2 and 3 waveforms are also slightly improved, but could partially be from changing point gap from 22 to 20...one manual says 22, one says 20...I'm leaning towards getting one from bnb while I work on other stuff...I had made a slow moving vehicle bracket, but I'll have to mod it...too close to the rockshaft mounted top link bracket when raised...I swear I measured it:(
Edited by dfwallis - 13 May 2025 at 2:13pm
1952 CA13092
