CA engine running issue
bigredneck61088 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredneck61088 Quote  Post ReplyReply Direct Link To This Post Topic: CA engine running issue
    Posted: 16 Mar 2016 at 4:42pm
Hey guys,
A little background on my stumping issue, I have posted before about it and have worked out most of the bugs... but i still have this continuing issue. (check my prior topics if you want more background, i'll brief it here)
1951 CA, willed to me from my grandpa and it sat for 6-7 years. As far as I know it ran when it was parked. The tractor has a 12v conversion with 12v generator, regulator and a 12 v coil.  After troubleshooting, it has gotten the following new parts; intake/exhaust manifold/gasket, plugs, cap, rotor,  wires, coil (correct ohms for this motor per the forums), points/condenser, carb (re manufactured), all fluids. I have also adjusted the valves, checked gas flow in carb, ran with gas cap off, ran it at night (checking for jumped spark), checked timing several times. I have also ran new wires from ignition to coil and solenoid.
When the tractor is started up, it runs fine. After running for 15-20 mins, it will randomly spit and sputter and hunt when at 3/4 - full throttle. If you back the throttle down it will correct itself. If it dies, the tractor will start right back up at idle, and run at 3/4 - full throttle, but never fails if the throttle is above half, it will spit sputter hunt and try to die. I do not believe its the coil because the tractor will fire right up after it dies and it doesn't seem to effect it when it dies. There does not appear to be any sediment in tank, carb was ok the last 3 times i pulled it apart. Checked flow, etc.
I thought i had it fixed after new points/condenser because I ran it this winter after replacing points/condenser and it did not spit, sputter, hunt/die. That was when the temp was 15-30 degrees F or so. It 65 here today, and was in the 50s and it did it again. The choke does not fix the sputter if pulled when dying. I even messed with the timing thinking it was too far advance, but no chance. I am in the process of getting a light to get it exact again. I did alot of it by ear, and got it pretty darn good before.
Any ideas? I checked the metal fuel line near the block it was somewhat warm but did not seem warm enough for vapor lock. I thought about ripping the distributor apart, but that wouldn't explain the temp issue. I am pretty mechanically inclined and have worked on a lot of things before, but this thing has me pulling my hair out.... I want to keep this thing for around my future cabin planting food plots and such, but not the way its running...
Edited by bigredneck61088 - 16 Mar 2016 at 4:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 5:10pm
Sounds like a fuel restriction. With the gas shut off at the sediment bowl, remove the drain plug from the bottom of the carb. Place a coffee can or something under the carb and turn the gas on. You should get  solid near pencil sized stream as long as the gas is on. You may have something floating around inside the tank that gets sucked over the hole or the line could be partially plugged.
Edited by CTuckerNWIL - 16 Mar 2016 at 5:12pm
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 5:18pm
It sounds like the tractor is surging.  Is the surge prevention spring in place on the throttle rod (the rod to the carburetor throttle)?  Start the tractor and hold the throttle rod with your fingers see what kind of result you get when you throttle up and down using your hand.  (be careful not to touch the manifold).   If controlling the rod will solve the problem, then you need to add the spring if it is missing.  Also, check the air adjustment on the carburetor.  It should be turned all the way in and then backed out about a half round.  Larry
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 6:22pm
I think I ask before but couldn't find it, where are you in Ohio?
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 8:52pm
   Sounds like fuel problem. I know that you have done this already, but start at the source (the tank) and work your way down again.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 8:55pm
I agree.  Check to see if you have the anti-surge spring. It connects to the middle of the rod that runs from the governor to the carb (should be a hole in the rod), and extends up to one of the manifold studs.  It's not weather sensitive, it can act up whenever it feels like it.  AGCO carries them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredneck61088 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 9:41pm
I appreciate the advice so far, you guys are the best with ACs, and i will check the governor... I understand what a surge/hunt is and it does not appear to be governor related but i haven't tore into the governor, it always seemed to work as needed and is hooked up. I cant recall a spring going to the manifold or not though, can one of you guys send a pic of what its supposed to look like. This tractor had some mickey mousing so i want to make sure. It has a spring on the distributor side that hooks to the governor, but can't remember if there is one on the carb side of the engine or not.  Not a fuel tank issue I have checked the lines/carb 1000 times it seems like....
Got an update, i put a timing light on it tonight and got a surprise. Checked the firing order and everything is good. With the light at full throttle, It runs worse when the fire mark is in the hole, and my previous timed by ear it was running a touch advanced. However the fire mark/line is floating around the whole. This was a surprise to me and the mark never was consistent in where it hit with the light. Distributor worn inside? i checked the shaft and it felt tight but never pulled it off in the "It ain't broke don't rip it apart." mentality..... I know these points ignition systems are finicky, Am I on the right track now? Distributor worn internally? Also ran it for 10 minutes or so and granted it didn't run as good as it did, but it didn't try to die like before either. I am gonna run it for a long period tomorrow and see if it still tries to die.
I am up near akron/canton area of ohio by the way
Edited by bigredneck61088 - 16 Mar 2016 at 10:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 9:55pm
Don't tear into the governor, your problem is not in there.  With your timing results, I would look at your carb settings again - sounds like it could be a restricted fuel flow.  Check the screen in your sediment bowl even if you do not see any debris in the bowl itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredneck61088 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 10:01pm
Did that tonight at well, fuel flow is great and I put a new screen in a month or so ago, its clean! i feel like I have checked the fuel 100 times, and everytime it flows great. I also messed with the carb again and it doesn't change it. Doesn't seem like fuel to me and have checked the fuel system a bunch.
Edited by bigredneck61088 - 16 Mar 2016 at 10:02pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 10:37pm
Check ignition advance change with engine speed. It should be advanced more the faster the engine is running. If the centrifugal advance mechanism hasn't been lubricated it can be rusted fast.  A way to check is with the distributor cap off, you should be able to rotate the rotor in the direction it turns and so move the cam and the rotor to advance the spark and when you release the rotor it should snap back.
Gerald J.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 11:18pm
Seems to me years ago dist. had a short jumper wire that went down under the point plate. don't know whether your dist. has this wire but sometimes they would short out. Time to long, memory to short, huh, Shameless?   Leon    Cmo
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 12:36am
Is the humidity hi & temp. cool when this stalling happens, and does the gasoline in the tank have a small % of alcohol ? If so the main nozzle in the cab. is icing up. If you let the engine warm up a long while, & the problem goes away that's great, but if not you my need to warm the air going into the air cleaner pipe. By using the heat from the muffler. I use a old medal 5 gal. bucket, I put a hole in the bottom, to one side for the muffler to stick through. Put it over the air intake & the muffler, it works great on my 140 IHC , with the same problem.  GOOD LUCK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 6:13am
It sounds like the advance in the distributor is not free.  You have to remove the points, condenser and the plate they mount on to get to the advance weights and springs. I have had them rust in the past. I have cleaned them up to get them to move free.  It is not all that complicated, it just takes a little more time than changing points.
When I was farming I had an Oliver 1850 that would run like a top at half throttle until you dropped the plow and it would die. Sputtered at full throttle and would pull its self. I was sure it was the carburetor and after what seemed I had it apart enough to have myself trainer as a carburetor assembler. I pulled the distributor out of my Oliver 1650 and put in the 1850 and put it to work.  I took the distributor apart and the weights would not move at all because of the rust.  The springs were good so after cleaned up it went back into the 1850.
Edited by Dick L - 17 Mar 2016 at 6:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 6:54am
With the erratic timing, I'm not a betting man normally, but it sounds to me like an Ignition related problem. And I'm thinkin' there's a problem in the Distributor with either the points, (rub block) main shaft runout, or the centrifical advance isn't working correctly. Could be a broken advance spring, or oil or rust that got into the advance weights making things murky in there or rust hanging things up and slowing down the advance. It could be the advance isn't working at all. I'm with Dick on that one. What I do in all my rebuilt Distributors, I coat the advance weights, and the weight plate that the weights ride on with dry graphite lube before reassembly. This keeps the weights moving freely all the time. Do not put oil or any lubricant on the weights. That just attracts dirt and ozone from inside the Distributor. HTH
Steve@B&B
brenpak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brenpak Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 7:01am
Make sure there are no floaters in tank!! same thing happened to me on my 52ca I Thought it was temp related also because it would seem to happen after it warmed up anyhow make sure there are no floaters and make sure if you have a inline filter that that is not plugged check it by removing it and put a jumper line in just to try!! I pulled my hair out trying to find the problem I got advise on this forum on what to check I did not believe it was fuel related BUT IT WAS!! I cleaned tank with vinegar and a chain and removed inline filter cause I Know for sure it is clean now as before same as you, it appeared to be clean!! Now it runs with no issues just my experience. Flow would be great when floater is not sitting on the inlet of the bowl, put a tube/filter up in the
sediment bowl so inlet is not picking up fuel off the bottom. Please let us know what it was/is when you fix
Edited by brenpak - 17 Mar 2016 at 7:07am
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 9:00am
The condenser is junk! Call Steve or Tony and get a good brand of new points and condenser.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredneck61088 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 9:14am
Steve@B&B
DickL's comment and this makes the most sense to me right now, especially since it sat in a dirt floor barn for 6-7 years without running.... I am going to do some more tinkering today and see, probably couldn't hurt to get the distributor rebuilt, I have done the same thing DickL did and have messed with the fuel system and taken the carb apart a million times and I am convinced it has nothing to do with fuel.
Edited by bigredneck61088 - 17 Mar 2016 at 9:16am
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 9:19am
I hate to chime in with such highly respected mechanics cause all the information they give is outstanding.  I keep thinking it works fine when cold.  How about the coil or perhaps cheaper - the condenser?
Remember, I worked on these units when they were relatively new so things such as Dick L or Steve is mentioning we never thought of.  However, they could be your answer.
In any event it is your GRANDFATHER'S TRACTOR.  Do all you can to get and keep it running right.  It is an extremely meaningful unit to have.
Let us know how it goes.
Good Luck!
Bill Long
ps: the CA is a neat tractor.  Peppy for it's size and easy to handle
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredneck61088 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 10:57am
You two guys might be my heroes, I never have had another CA to look at to know if it was missing anything, and overlooked this the first time
Well gentlemen, I may have made some headway this morning. I took the distributor apart and cleaned it up, the advance is pretty simple once i see how it works and it may have been sticking a bit. Started her up and she runs pretty good now. Points were good and reset the gap and put it all back together.
However after rethinking this again and reading the above posts, I took a look at the governor.... I am missing the spring on the carb side of the engine as mentioned above by a few smart fellows, and now after looking at the distributor it looks pretty decent, and I think this missing spring may be the missing link per se. I don't want to jinx myself but i ran it at full throttle and played with the carb side shaft where the spring would be, it runs smoother when i hold it by hand. Can someone take a pic of this spring and where it mounts, and what it looks like?? I don't want to purchase the wrong one, and want to see what it looks like mounted, crossing my fingers but this may be it....
http://www.steinertractor.com/ACS304-governor-rod-linkage-spring  is this the one i need??  Or is there any similar spring i could find locally to test/try... I don't think TSC or Napa would have that one
Edited by bigredneck61088 - 17 Mar 2016 at 11:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 11:02am
One way to prove out the stuck advance before taking the distributor apart is to set the TDC line in the center od the inspection hole. loosen the distributor and rotate back and forth making sure the points are just about to open, tighten it down. Start the engine and check with the timing light and the FIRE line should be in the center of the inspection hole. If it can not be seen at all the advance is stuck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredneck61088 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 3:30pm
Who knows anything about these governor systems/adjustment, I went through carb and everything again today and it will purr like a kitten up to 1/2-2/3 throttle, but any higher it runs kinda crappier but if I hold the governor rod, just slight pressure towards the rear it runs great.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 5:40pm
Terminology some times throw red necks like myself a curve. We have our own adjectives which gets confusing even to other red necks.
To adjust the governor linkage unhook the linkage on the carburetor side at the end of the governor crossover arm. Push the hand throttle all the way forward to the wide open position.  Pull the linkage from the carburetor forward as far as it will go. To be correct the linkage needs to drop in or lacking about 1/16" from dropping in. If this is not the case you need to bend the crossover arm so it is the case.
I have long arms and use a pipe on the end of the crossover arm and a large pipe wrench on the governor side of the arm and push or pull to get it bent to the proper adjustment. If you have short arms you might need a helper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredneck61088 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 6:43pm
Well I have some good news for once, I read DickL's post after i figured it out for myself.... So throughout the day, i read manuals, went through the fuel system again, checked timing, checked all wires, regapped and cleaned plugs, made a test spring for the governor, read some more, read on the forums, etc etc.... so after wasting all your guys time, and messing with the governor for 3 hours, I figured out this whole time the governor was not properly adjusted to start, i need to rebend the crossover arm as DickL stated, but i figured that out before i read this post and he just confirmed my suspicion.
So i can only get 1/2 way up the tree before the governor kicks in and it starts running slightly rough, but since its not adjusted right, it lets me go the whole way up the tree but runs crappier and attempting to be governed. I am used to newer engines where the governor basically stops you from that. I read in the manual that max RPM is 1800ish, I had been trying to get this thing to run at higher RPM than suggested and that is always why it ran crappy in one instance or another... and i had the timing advanced to compensate for it.... Which would explain why it used to die when it got warm. Its missing the spring as well on the carb side, and plan on ordering one.
So after all that, she purrs like a kitten throughout the range, will idle surprisingly super low and runs great up to 1/2 way up the tree. It is super smooth for 1951!!! I will eventually bend/lengthen the arm to make it correct and fine tune it, but my grandpa must have just known to not go that far on the tree which threw me off.... She has been running most of the evening and is doing great! Any thoughts/questions/concerns/something i missed??
Thanks for all the help guys, I know it was one big troubleshooting mess, and i appreciate all the input!!! I would have been able to figure this out a lot quicker if I had another CA somewhere to look at Tongue! Here is a pic of her, had to put the good side out as the other rear wheel is pretty rusty from some leaky calcium my pap had in them...
Edited by bigredneck61088 - 17 Mar 2016 at 11:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredneck61088 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 11:42pm
Sure enough, went back out and messed with the governor rod, and got it closer than it was before, not quite 1/16 yet as the carb side rod is shorter.... but the longer she runs the better she gets, i also have more throttle on the tree now too!! she should be ship shape now fingers crossed, thanks again guys
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2016 at 3:28pm
Nice looking CA
Tom
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2016 at 10:02pm
I have a cousin south of Hinckley with a B.  PM me and I'll give you his #.  He has a buddy with a dozen or so AC's south of him.  Sometimes just getting someone else to look at it makes all the difference in the world.
Good Luck!
Allis Express participant
