CA Crankshaft
KChallener View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KChallener Quote  Post ReplyReply Direct Link To This Post Topic: CA Crankshaft
    Posted: 06 Dec 2023 at 1:04pm
My newly acquired CA has a bent crankshaft. I have searched all the websites I can find to no avail. Anyone have a suggestion or know where I might find one?
Thanks,
Ken
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 3:06pm
I have plenty of them, although I'm in Maryland very near Gettysburg, Pa.  I'm sure if you call Branda at Sandy Lake Implement, they'll have something for you. 724-376-2489
Sandy Lake Implement is right in you area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 5:13pm
I sent you a private message
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 7:25pm
How does a crankshaft typically get bent??  They're pretty beefy.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 7:37pm
The torsional "twist" imparted through them with clutch engagement having a heavy load to pull. When you set the shaft up on blocks and rotate it using an indicator on a round bearing surface this minor twist results in the shaft "heaving" which is interpreted as bending. They don't bend as such like folding apiece of metal over in a bench vise.
Edited by Codger - 06 Dec 2023 at 7:38pm
That's All Folks!
jdeere562 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdeere562 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 11:24pm
I bent one once in a WC pulling tractor. But had beefed up the engine some. Put in a WD45 crank and rods for more stroke. Had some 4020 JD sleeves machined for the block and 454 big block Chevy pistons as I recall.
Also reworked and ported the cylinder head, intake and exhaust. Ran a D19 carb, had to drill jets to get it running properly. Always wanted to hide a nitrous bottle somewhere...LOL!
It would normally spit out the PTO gearbox on the dyno, before you could get a HP reading. Been a lot of years ago.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 4:58am
I have several, but a little ways away.
http://lonsallischalmers.com
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 5:23am
I'm still trying to figure out how a "CA" engine would ever have enough BANG in the combustion chamber to bent a crankshaft ??  Must be a bearing burn out related failure ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote KChallener Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 4:55am
Thanks for all the comments. I will call SLE (Sandy Lake). It looks like the A, C, and CA cranks were all the same? Pull the crank, mains, etc. Rod bearings were burn and scored. My guess is that there was a main failure at sometime, probably number one. Someone's been in there before, lots of Permatex. Before dissassebly I was getting about 45 psi compression on all 4 - any thoughts on that?
Ken
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 5:55am
B, C and CA are all the same. A is an entirely different, and significantly bigger engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 6:07am
45 psi cranking with an electric starter spinning the engine ?? Pretty poor. Double that would be much better.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 7:26pm
Originally posted by KChallener KChallener wrote:
... I was getting about 45 psi compression on all 4 - any thoughts on that?
Ken
 Better check cam timing, that's mighty even for being simply worn.
Edited by Les Kerf - 08 Dec 2023 at 7:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote KChallener Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2023 at 6:23am
THanks. Will check pressures again after new pistons, sleeves, rings, crank and bearings.
Ken
