CA crank pulley removal |
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2580 |
Topic: CA crank pulley removalPosted: 14 Nov 2023 at 5:15pm |
![]() I only looked at this briefly. Socket won’t fit cause pulley sheaves in the way. Screw head didn’t move. What is the combination to crack this case? 🤔Thanks! Dana. |
Blue Skies and Tail Winds
Dana |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5164 |
Posted: 14 Nov 2023 at 6:27pm |
Crowsfoot wrench. Be sure to make a horseshoe plate to support as much of the pulley as possible before pulling with a puller or you'll crack the pulley for sure. It also helps to warm the pulley good before putting it back on.
Edited by PaulB - 14 Nov 2023 at 6:27pm |
ORBill
Posted: 14 Nov 2023 at 8:01pm |
What Paul says. I just did mine. Soaked it with penetrant, ground a little off an old wrench to sort of fit, nut broke loose then screw came out pretty easily. I did break the tip off a screwdriver trying to get the screw out without getting the nut loose first.
captaindana
Posted: 14 Nov 2023 at 8:20pm |
Ok thanks y’all
Dana |
Posted: 14 Nov 2023 at 9:40pm |
Loosen the nut but leave it in so the screw slot doesn't spread open.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 14 Nov 2023 at 10:20pm |
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2682 |
Posted: 15 Nov 2023 at 6:03am |
I used a bearing separator to pull the pulley off a b. You have to support the bearing so you're not pulling against the pulley itself. Yea lube and maybe heat. Good luck.
Codger
Posted: 15 Nov 2023 at 6:06am |
I use a two jaw bearing splitter with two pulling rods, a threaded cross beam and forcing screw for these. Think I have four different sizes of bearing splitter so something always works. Long and short is you need to support that sheave almost complete around it's backside while forcing on the crank snout.
That's All Folks!
