CA carb question
bshook78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bshook78 Quote  Post ReplyReply Direct Link To This Post Topic: CA carb question
    Posted: 27 Sep 2012 at 4:06pm
I am trying to locate a part number for the carb on my CA.  Where do I look?  I am needing to get a kit for it, but I'm not sure what I need.  Any help would be appreciated.
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 6:07pm
My parts catalogue mentions Zenith model 161j7 or Marvel-Schebler assy. # TSX-486.
any of our great advertisers-supporters-members here would be able to tell you much more than I.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bshook78 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 7:39pm
Thanks Steve.  I will try to post a pic tomorrow and see if anybody can possibly identify it.  I am not sure where the part no. should be located.  I looked earlier, but I am guessing I will need to take it off to find it.  I haven't gotten that far yet.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 9:31pm
The carb should have the mfg name on the side of it. The model # is usually on a brass tag on the top of the carb. Once you know the mfg of the carb, a kit is not had to find unless the carb is not original to the tractor. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 11:04pm
CA's had either a small bore Zenith or a small bore Marvel Schebler on them. The Zenith has a disc rivited to the top of the float bowl about the size of a dime. Outside number on the disc is the AC number. The number stamped in the disc closest to the rivet is the Zenith number. On a small bore M/S carb, a round tag is riveted to the side of the float bowl area. In most cases, the M/S number starts out as TSX- xxx then a three number digit. ie- TSX-470.  Once you ID the carb and its P/N you can get any part needed for it. If you're looking for a rebuilding kit, we have a whole wall full of em'. Just need to know what ya got. Be glad to help you out.....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote bshook78 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2012 at 4:09pm
Thanks.  I am going to check it out today.  I hope to find out something in a little while.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bshook78 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2012 at 10:29pm
I found out that it is definetly a Zenith.  It has a B14 on the bottom, and it has C21-78 on the disk.
This page was generated in 0.091 seconds.
