CA Brake Drum
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: CA Brake Drum
    Posted: 19 Nov 2025 at 10:59am
I am in need of a serviceable brake drum for an Allis-Chalmers Model CA tractor, this is the brake drum that is an integral part of the hand clutch assembly.
AGCO lists the part number as: 70225605
tadams(OH) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2025 at 1:40pm
I have the whole asembly housing and all but in ohio.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 12:05am
You can get them new from Agco for over $400. I have rebuilt them. I turned down the drum and sleeved it to give it a new brake surface.
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 8:00am
If it weren't quite so far from Idaho I would be very interested in that Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 8:07am
Whee!
I never thought of sleeving; machine shop rates would probably end up being upwards of just purchasing a new part from AGCO Shocked
Is it feasible to build it up with weld or is that just a dumb idea?
streetguy1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetguy1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2025 at 6:10pm
I have a CA handclutch already has new dics like paul was talking about I sold one that Rick had rebuilt to Micheal Crowe so you can check me out with him I can text you pictures if you want 200 dollars and you pay shipping 6412023665 think iput new balls in too John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2025 at 7:57am
Thanks for the reply, I had already commited to another source prior to seeing your post. I may re-consider if the other source doesn't work out. Smile
This page was generated in 0.174 seconds.
