CA BEARING FOR DROP BOX
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: CA BEARING FOR DROP BOX
    Posted: 22 Oct 2024 at 8:24am
For a CA BEARING, CONE AND CUP for CA Allis drop box on rear right side. Part numbers would be appreciated.
Part numbers for off the shelf would be appreciated.
numbers 24 and 25
Edited by WD45 - 23 Oct 2024 at 8:37am
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2024 at 7:31am
Do you have better discription of which bearing
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2024 at 9:26am
These are the numbers i used on rebuilding a couple "B" tractors... I beleive the CA uses the same..
Rear Axle top pinion shaft
Differential seal          1.250-2.004                 .468 lip seal          CR12458         NAT410163R
Carrier bearing
center brg                    TIMKIN                      tapered roller        14138A (brg)-14276 (race)
center seal                   1.375-2.720                 .468 lip seal          CR13900          NAT450456
Outer brg                                                         tapper roller          14138A(brg)- 14276 (race)
                              (seals from CR end up being 5/16 or 3/8 wide single lip)
Rear axle bull gear shaft
Inner brg                                                          tapper roller          14138A (brg)-14276 (race)
Outer brg                     TIMKIN                      tapper roller           368 (brg)   -- 362 (race)
Outer seal                    2.500-3.548                 .500 lip seal           CR 25065         NAT415001
(seal from CR is double wall, single lip, maybe 3/8 thick)
Edited by steve(ill) - 23 Oct 2024 at 9:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2024 at 9:32am
prices vary drastically depending on Manufacturer...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2024 at 9:34am
Mike, these are the inbd and outbd BULL shaft bearings on a CA... if you GOOGLE the part number for the outbd it comes up with 370/362 .... and not 368/362 .. ??? not sure why ?
Edited by steve(ill) - 23 Oct 2024 at 9:39am
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2024 at 8:38pm
Thanks everyone for your help. Now to get it apart.
This page was generated in 0.049 seconds.
