ca battery ign.distrib.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Topic: ca battery ign.distrib.
    Posted: 19 Apr 2012 at 7:51pm
all my rest and overhauls have been on the 45 diesel mostly,will a ca dist.fit on a b allis???
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 7:59pm
Yes
Bill B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 8:05pm
The CA distributor has a gear drive off the governor. If the B had a distributor driven off the governor it will interchange. If the B is an early mag ignition they won't interchange. If the B had a conversion with a right angle drive, the distributor might fit the right angle drive?????
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 10:07pm
Use the entire distributor drive, governor, & all off the CA. It bolts right up. Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 8:45pm
thx from an old diesel doctor...j.w.
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 8:47pm
thx kip...j.w.
