CA allis electrical diagram
CentralMNCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CentralMNCA Quote  Post ReplyReply Direct Link To This Post Topic: CA allis electrical diagram
    Posted: 30 Sep 2024 at 7:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2024 at 8:44pm
your drawing is too small for me to see details, but it appears to be hand drawn, have a 12 v battery with a voltage regulator and negative ground.. dont see a distributor or mag... something like this ??  What is the question ?
OK.. i see the coil / distributor and push switch on the starter.... my terminals on the coil and BACKWARD....power comes into the + terminal..
Edited by steve(ill) - 30 Sep 2024 at 8:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2024 at 8:14am
This is the ALLIS CHALMERS wiring diagram for magneto equipped B,C & CA tractors. For distributer equipped tractors a key switch and wire from the ammeter is use in place of the grounding magneto switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2024 at 8:37am
He has a 12 v Negative ground system with a 4 terminal voltage regulator and a distirbutor / coil ignition system..... not close to a factory CA wire system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CentralMNCA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2024 at 11:36am
Thank you guys for your reply's, this is my first time at trying to install a picture on the forum, and I failed, I will try again with a better picture, please be patient with me as I try to get it correct and readable, I tried posting with an apple I pad,   Steve awhile back you posted an explanation on how to post a picture somewhere on the forum and I have not been able to locate that information.   once I figure out the procedure for pictures  it will make better sense,   Again thanks for all you help
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2024 at 12:39pm
Make your photo about 800  x 600 pixels in size.. you can do that on a computer PAINT, or e-mail it to yourself and resize on a cell phone..
Click on POST REPLAY icon at the bottom left side of this page.
that brings up a box... click on the GREEN TREE icon at the top of the box..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2024 at 12:40pm
