CA 3-Point Sickle Recommendations?
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA 3-Point Sickle Recommendations?
    Posted: 3 hours 24 minutes ago at 7:52pm
Considering a sickle mower for road and ditch trimming.  Prefer 6 or 7 foot.  No experience, what's a good RELIABLE recommendation, esp brand wise?  Not a situation of wanting a native or fixer upper unit at this time.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 46 minutes ago at 8:30pm
no brand, just a comment.. I have an old 1940  Allis sickle mounted on a B tractor.. Works OK... but it would be nice if  you could angle the bar and cut on slopes and hill sides... The old pitman arm type you can only tilt a few degrees from horizontal... Some models are belt drive out the the bar/ cam shaft area.. Those you can tilt quite a bit ... Something to keep in mind..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 18 minutes ago at 10:58pm
Buy an AC  82T trailer type is best bet. Easy on and of. Cut in almost any position. Use one around our pond. Works Great! Tracy
