CA 3 point
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Topic: CA 3 point
    Posted: 23 May 2010 at 12:54pm
Any one have a 3 point conversion kit for a CA in the Ohio area?  I would like to put one on mine and thought I would see if anyone has a used one.  I want to find the kind that I can keep my draw bar on.
 Thanks,
 Joe
Life is simpler when you plow around the stump.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 3:02pm
TonY Carbaugh has them and there  are not too expensive, less than $300..  tonystractors.com   There are two varieties that fit the CA. Image 8 is the best one
Rayhowling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 3:41pm
I made 3 PH for my 1955 CA 20 years ago and still use it for several 3PH implements. The  draw bar  guide which holds the draw bar, about half way down the guide I cut a hole in each side and welded a 1 inch pin into the hole and let about 3 inch stick out on the outside of the guide. I than made the 3PH arms out of 5/8 X 2.5 inch flat bar and bought 4 3PH steel balls  from TSC and welded tham to the flat bars and took the snap coupler lift brackets off of my 2 furrow Allis Chalmers plow to lift the 3PH flat bar brackets. I welded 2 pcs. 3 inch long to the pipe that lifts the snap coupler arms for the 3rd link. I spend less than $20.00 and it still going.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 4:21pm
Ray, that sounds interesting......could you post some pictures? Thanks.
WC, CA, D14, WD45
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 5:49pm
TSC sells complete lift arms also
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 8:53pm
Dave,
 I am going to Boise Idaho for a few weeks to visit daughter and family and will post some pictures when I get back. The Allis CA was made in 1955 and my brother and I were with my dad when he bought the tractor from the dealer in April 1956. It is a keeper, 4 year old grandson likes this tractor best of  all the tractors. I just found the original invoice several years ago $1820.00 and $331.00 for a two row corn cultivator, still has the original sheilds.
