CA 3 Point Mower
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: CA 3 Point Mower
    Posted: 06 Sep 2021 at 9:18pm
I recently bought another CA with a wide front. Put a Cross Mfg. 3 Point on it. I have Woods L306 on my narrow front CA which I like. Would I be better off with a Woods 3 Point Mower or is there a better mower to look for? I want a 6 foot mower. If I found another Woods are the blades and spindles the same as the L306?
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2021 at 10:27pm
I've had both an L306 and a 3 point on my CA not at the same time. The CA isn't heavy enough for a 3 pt mower. When you lift it the front gets very light and it handles poorly. The only way to lift the 3 pt is to have the mower running. I found it a very bad option. I put the same mower on my WD45 and the L306 back on the CA. I have no lift cylinder on my Belly mower it's blocked in one position and works great.
Edited by Dakota Dave - 06 Sep 2021 at 10:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2021 at 10:32pm
The woods 3pts use right hand blades your L306 uses left hand blades
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2021 at 6:44am
I pull a 6' finish mower with my CA no problems, I guess it depends on what you want to do, I use my CA to break ground, disc ect, so it is easier to use a 3PH for me.
