C water pump?
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Topic: C water pump?
    Posted: 27 Jun 2018 at 4:37pm
I have a water leak in my C, thought it was hose but appears to be the water pump. My question is can you remove the water pump without removing the radiator? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2018 at 8:47pm
IIRC you can remove the pump w/o removing the radiator but it is a pain. Not much trouble to remove the radiator and gain a lot more working room.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2018 at 3:14am
If you have little hands with nimble fingers, it can be done.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2018 at 12:12pm
I think you can have the radiator off and out of the way, faster than getting one bolt out of the fan. Only the shroud bolts and the 2 on the bottom of the radiator.
