c smokeing and back fireing
Daniels wc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniels wc Quote  Post ReplyReply Direct Link To This Post Topic: c smokeing and back fireing
    Posted: 03 Dec 2018 at 10:15pm
Was wanting more incite why would a tractor spits spuders back fire and smoke. I am working on an allis charmers c,it had the engine tore part when I got it. I was told that it had all of the symptoms. Above and whounder what might cause that
Thank you Daniel
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2018 at 6:33am
Can be lots of things but you got to start somewhere so I''ll say check the spark.  Must have bright blue spark at the right time including plug wires on in the correct order.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2018 at 7:12am
I guess I'm not clear on where you are at. Is it still apart or have you put it back together and started it? How far "torn apart" was the engine? What is/was the condition of the internals? If you reassembled the engine what did you do to it for machine work are parts? If the engine is still apart are you asking what you should look for/at with the engine apart, that might have caused the symptoms?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2018 at 2:28pm
2 plug wires switched around can do that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniels wc Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2018 at 2:52pm
NO that means that someone tore the engine apart probably becuse 2 plug wires were mixed up so frustrating Cry
Thank you for the help Daniel
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2018 at 3:08pm
How far is it torn down?
If it's backfiring through the carb, I think timing.  If it's not truly firing through the carb, but hitting at a weird time and running rough, I think timing, spark or carb.  Could also be a valve.
If the head's just off and it rotates free and the cylinder walls don't look bad, personally, I would make sure the valves were good, probably lap them, install the head, put everything together correctly with a clean carb and known good mag (or distributor and coil) and see what happens.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2018 at 3:39pm
Points and condenser quality isn't what it used to be. A bad condenser will make them run bad and back fire. Also look at the distributor. If the shaft has play in it, your spark timing and dwell will not be consistent. Check the advance mechanism. The shaft will turn a little one way and spring back. When you set the timing it's done at full throttle and not idle speed. Also remember the firing order is 1,2,4,3 and NOT 1,3,4,2.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2018 at 4:43pm
The shop manual may have hints on trouble shooting and for sure details of timing both valves and ignition.
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
