C pulling engine
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: C pulling engine
    Posted: 04 May 2013 at 3:13pm
I heard you can put D-15 internals in a C block. How do you do this and is there any other ways to make a strong pulling engine for a C?
Can't fix stupid
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2013 at 3:53pm
you need to talk to Dick L.  im pretty sure he has some posted information and pics covering this topic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2013 at 9:37am
The D15 block will bolt up to the C,B, or CA.
nborga87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2013 at 1:53pm
how many cubic inches is the d15 motor  compared to a b and ca?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2013 at 4:06pm
The idea is to appear stock looking. Wanna make them think its just a basic engine.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2013 at 4:25pm
Late B, all C's and CA's
series II D15
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2013 at 8:56pm
wow pretty good difference you got me wanting to build one now haha! i recently saw a single front wheel ca for sale for 1000 bucks.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2013 at 12:54pm
Unless you weight up a C over 3500 or 4000, a well tuned Stock engine with a combine governor will spin the tires before running out of power.  If you don't have a less than 4 mph speed limit it may change things up a bit.
Work on eliminating wheel slip before spending a bushel full of money on horsepower
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2013 at 1:48pm
     Well, I guess I can put the video on again to show what you can do with more than the D-15 innards in the stock C block. It had the D-15 crankshaft machined to fit the C block. Also changed the stroke from the 3 7/8" stock to a full 4 inches. Sent the cam to crane for a special grind. increased the piston height to enter the firing chamber. had the engine balanced. I took .150 off the head and used SBC valves. Ported and polished the intake and exhaust. I opened up the manifold to match the head openings. I re jetted the stock carburetor to match the engines needs.
The first pull in the video I slowed the RPM's at the end to try for more grip which didn't work on that track. Second pull I paid close attention to my ground speed and increased the RPM's to overcome the tire slippage and not slow the sled. That worked.
If I was not 75 and still pulling I would never told this.
http://www.youtube.com/watch?v=hM4YbM8keMM http://www.youtube.com/watch?v=hM4YbM8keMM
Edited by Dick L - 30 May 2013 at 1:49pm
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2013 at 12:01am
d15 series II is 160 cubes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2013 at 8:55pm
If Dick didn't run outta' track, that little C would've pulled that sled into another zip code!
Nice pull Dick!
Steve@B&B
