C Overheats
Mitch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mitch Quote  Post ReplyReply Direct Link To This Post Topic: C Overheats
    Posted: 14 Jun 2025 at 9:04pm
I have a C that we have had in the family for as long as I can remember. It has always had an overheating issue and thought I would try to solve it :) I started with the thermostat but when I took the housing off there was nothing in there and not sure the one I purchased would even work. Thought I read somewhere that the older ones didn’t have thermostats. Mine is 41.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2025 at 10:33pm
Most of the older ACs (and probably most other brands as well) did not have thermostats. You had either canvas or a metal louvered shutter in front of the radiator to block off airflow in colder weather/lighter load conditions to allow the coolant to warm up to an acceptable range.
So, you know a non-working or clogged thermostat is not your issue since you don't have one, ha. Is the radiator cap correct and in good condition? Are the fan blades angled the correct direction? Radiator fins completely clean? Shroud sheet metal on the backside of the radiator around the sides of the fan present?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 6:41am
How do you KNOW it is overheating?? By trusting the 60 year old temp gauge ?? or does it actually vomit coolant out the radiator cap ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mitch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 9:44am
I put a new temp gauge on, but it also comes out the overflow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 9:51am
over the years many used well water or creek water to top off the radiator... and NEVER did a flush.... Probably have a couple inches of dirt packed in around the block / liners... maybe in the radiator also... take the hoses off, connect to a garden hose and BLAST AWAY !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mitch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 10:57am
That makes sense and yes thermostat issue solved ;)
 So, concerning the radiator, the radiator fins are clean and not clogged, fan blades appear correct and the shroud on the backside is good.
Not sure about the radiator and cap though. I don't think the radiator is original and not sure if the cap has the correct pressure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 12:28pm
Often a FORD type cap with a 3/4" reach has been put on. ALLIS CHALMERS need a 1" reach cap.  Also the sediment can get packed so tight around the sleeves that flushing will not remove it.  Removing the head will help to get some of it dislodged, however removing the sleeves and thoroughly cleaning the block is the only way to get the worst of the sediment out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 4:10pm
If the radiator has been replaced, then you may have to sort out what the correct cap for it is to make sure that's right. Who knows what type of neck an aftermarket radiator from China or Turkey has. However... if the gauge is showing it's overheating, and it's pushing fluid out, then it probably is actually getting hot.
The other easy thing I forgot to mention is that if you keep filling the radiator up to the top, it will keep pushing fluid out as it heats up and expands every time you warm it back up. There is a normal level that the radiator will keep returning to and there's not point in tipping it off. Again, if the gauge indicates it's actually overheating, then an overfilled radiator plus expansion is probably not the reason for the coolant overflowing... But I wanted to list all of the easy to check/replace things first.
Like the other guys said there's a good chance the radiator or block are scaled up. Those are not as much fun to fix.
There's a possibility the water pump impeller is way worn down, but I don't think that's common as most of the pumps start leaking well before the impeller would ever show any damage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2025 at 4:26pm
A good start would be to take an IR thermometer to it after its warmed up.  Look for hot spots, and then follow through...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mitch Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:29am
Thank you for all the good information and ideas.  I will work through them.
If I just wanted to start over and replace the radiator so I know what I have, is there one that you guys prefer or recommend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:15am
Flushing the system is a lot cheaper than a new radiator... unless you have a good reason to suspect the radiator is the problem..... the B-C tractors nomally run COLD as the radiator is plenty big for the engine..
Edited by steve(ill) - Yesterday at 9:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:17am
I would almost bet that if you pulled the head off, you'll see Daytona beach packed around the sleeves. When I did my B 20 years ago, I couldn't believe the muck that was around the sleeves! I was rebuilding the engine anyway, but the muck that came out of that engine was incredible! I remember the previous owner telling me it boiled over a few times. After I finished up the Tractor, to this day that Tractor never gets hot. Half the time when I'm working it, it doesn't even get up to the "green" range on the temp gauge even on a hot n' humid New Jersey summer day....  HTH
Steve@B&B
